March 1, 200719 yr Does anyone have the instruction sheet from H5010FE056 OE Gauge kit http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=013&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=230096944996&rd=1,1 I need a copy of the instruction sheet. nipper
March 2, 200719 yr Author That helps to a point. Thanks. At least now i know which ones illumunate the gauges. Here is my problem. I ahve the JDM oil temp/oil press/volt gague set. They do plug in, but the oil ones dont work. I have the factory harness and sesnors There is a mystery black box behind the gauges, which i have no idea what its purpose in life is. It has a chip in it and some sort of power transistor thingy (I can take pics of this if it helps). It is a factory peice, maybe an inch long. Also on the harness is a wire with a blue connector cover (blade terminal male). It is factory, but I dont know if thats a power or a ground. I am wondering if i can just bypass the black box, as it seems to have only three goes going to it. Any ideas?
March 2, 200719 yr So why exactly are you looking for instructions for H5010FE056? I would expect it to me some fairly recent WRX STI gauge pod, similar to the one I posted a link for. I tought you bought some 1998 wrx sti one. I'll try to hit a couple of guys on russian forums, who might have more info, since a lot of old Japanese cars are making it to Russia
March 2, 200719 yr Author Well subaru being subaru, and they rarely change things, i was oping that would give me a clue. On the ebay pictures i saw the same colors and same mystery wire on the harness. I was hoping it would help. nipper
