Need Help - Broken Belt Tightener
Hell all,
I have a 1997 2.2ltr Subaru Impreza Outback Sport wagon. I was trying to tighten the belt on the passenger side by turning the belt tightening screw. It was very cold out when I was trying and the bolts I was suppose to loosen before tightening were interfering. I cracked the piece that the screw you turn to tighten the belt goes through. Once I tried to tighten it again when it got warm out, it simply came apart. I need to replace the part that the screw goes through so I can install it and start driving the car again. Does anyone know the part number for this piece (or at least the proper name for it). I can not find it in any of my part number books and papers. Thanks!
BTW: Below are some pictures of the piece I need to replace.
kevin, post that picture in the parts wanted forum, someone probably has one they can send you?
i have one in maryland...but i'm not there right now. i might be there sometime this week, if i do i'll try to remember to snag it for you.
I will be posting a picture shortly. Thanks!
Got it! Part is simply called 'Adjuster'.
Subaru part# 73134AC001
Amount: $6.48 at the dealer. You should be able to get it cheaper.
Picked it up and will install tomorrow. Thanks for everyones help. ;)
