March 20, 200719 yr The car in question is my 2000 obw but the question probably would apply to many other models. Each Monday I have to set the clock backwards by around 2 minutes. I find this rather annoying that in this day a clock will not keep reasonably accurate time. That said, I will not pull the dash apart for just the clock but if I am in there in the future I was curious if there is an adjustment to slow or speed up the clock similar to many of the quartz module clocks powered by a single AA battery found around the house? Steve
March 20, 200719 yr i don't think they're adjustable, did you check your owners manual? i'd probably snag another clock from a yard and swap it out, i haven't seen or heard of this happening before so my assumption is that you got a screwy one.
