April 3, 200719 yr I am looking at buying an inexpensive outback that I was told overheats during long drives, but not short drives. Without seeing the car, what are the chances of it actually being a head gasket issue? Is it worth it if I get the car under $1K or that ballpark?
April 3, 200719 yr I am looking at buying an inexpensive outback that I was told overheats during long drives, but not short drives. Without seeing the car, what are the chances of it actually being a head gasket issue? Is it worth it if I get the car under $1K or that ballpark? How many miles? Auto or manual? What else to you know about the car?
April 3, 200719 yr what are the chances of it actually being a head gasket issue? Depends on the mileage, though if it has been "cooked" once or twice the chances of needing a head gasket(s) increase. There are many things that can cause overheating, especially in a 10+ year old car. Is it worth it if I get the car under $1K Reality check: if the car is not driveable it is scrap. To keep said car from heading to a junkyard you are going to have to pay slightly more than a junkyard would pay for it. ONLY you can determine what the car is worth to you and using your instinct bid a price for the car you can live with. If it is your intention not to personally fix this car (pay a garage to do the work) there would be no trouble spending in the order of $2000 for fixing. How much is the car worth now?
April 3, 200719 yr Author It's on ebay and is currently under $600 with 2 hours to go. It has 161K and is an auto trans - ebay number 320097766936. That's all that I know.
April 4, 200719 yr i picked up my 96 outback for $250 and it needed headgaskets.i did the job myself for under $300.
