April 22, 200719 yr I was fiddling with my driver door power window & lock switch today, trying to see if I could fix the passenger window switch, and it...just...exploded on me. Plastic bits and electrical contacts everywhere. Anyone have the whole assembly for the drivers door they would be willing to part with??? Thanks in advance.
April 22, 200719 yr I did the same thing, However if you can find all the bits it is quite easy to repair just takes time (Unless you lost some parts). However after reassembling it, it worked again.
April 22, 200719 yr I was fiddling with my driver door power window & lock switch today, trying to see if I could fix the passenger window switch, and it...just...exploded on me. Plastic bits and electrical contacts everywhere. Anyone have the whole assembly for the drivers door they would be willing to part with??? Thanks in advance. If I knew the year/model of your car, I might have it.
April 22, 200719 yr Author If I knew the year/model of your car, I might have it. 1988 RX Turbo Coupe.
April 22, 200719 yr Unfortunatly, thats a model specific item. It has to come from a 3dr. I dont have a spare, even for my RX:-\
