April 24, 200718 yr Is there a difference between the 1.8 and 1.6 headgaskets? I see that the bores are the same.
April 24, 200718 yr 1600 Head gasket 1800 Head gaslet Dont mind the inversion between pictures, but you can see some differences like alignment pins
April 24, 200718 yr Author 1600 Head gasket 1800 Head gaslet Dont mind the inversion between pictures, but you can see some differences like alignment pins ok then, nothing but an ea81 gasket will wrk then . Thanks for the info . Regards Kim Webb.
