replacement screw for my weber 32/36
What part/screw are you looking for exactly.I have several webers and one I have for parts.I could send you the screw no problem just let me know its location on the carb ect.
Hi,The screw I lost is the one that holds on the lower arm on the auto choke body.If you go to http://www.carburetion.com/Weber/weber.htm and follow the links to the parts diagram page for the 32/36 I need parts 73, 74, and 75. 73 is a wave washer, weber part #55530.005, 74 is a bushing, weber part #12765.042, and 75 is the screw, weber part # 64700.014. If you could come up with those that would be sweet. I just dropped a used 1800 into my 82 Brat and I want to dump the hitachi and put in the Weber that came with it. Thanks, Frank :burnout::headbang:
