location of tranny fluid dip stick
hi everyone i cant seem to locate the dip stick for my 2000 obw. i need to check the level, there is a delay when i shift into drive from park. thanks
Should be on the driver's side, just medial and deep to the washer fluid reservoir. It's kind of hidden down there, and you'll have to navigate some hoses.
There are a number of posts of people who developed slow to engage into drive on '99's and some '00's. But yes checking fluid level reguarly is good to do. The procedure is in your manual; basically check in park engine running on level surface after vehicle has shifted through all gears.
