esh Posted May 17, 2007 Share Posted May 17, 2007 since I swapped to the weber, my a/c idler (or whatever it is) is not working. did anyone else experienced the same problem? Link to comment Share on other sites More sharing options...
Skip Posted May 17, 2007 Share Posted May 17, 2007 I think you mean your idle UP solenoid? Keeps the idle up when the AC comp. is on. These are different for different cars. Look for a devise that used to hit the thottle linkage in the area behind the carb, it will be an electric solenoid. You may have disconnected it with the new carb or it needs repositioned. Link to comment Share on other sites More sharing options...
esh Posted May 21, 2007 Author Share Posted May 21, 2007 the solenoid was re-adjusted but it seems like it hasn't got the power to move the throttle linkage. it is a vacum solenoid. i looked for air leaks but couldn't find any. Link to comment Share on other sites More sharing options...
