May 18, 200718 yr i searched and didn't find this. i got water pump, oil pump and cam seals. are there any additional cam seal orings or anything to address while i'm there?
May 18, 200718 yr i searched and didn't find this. i got water pump, oil pump and cam seals. are there any additional cam seal orings or anything to address while i'm there? Check the pullies for play. You might want rocker cover seals.
May 18, 200718 yr Author checked all the pulleys i also got the spark plug hole rocker cover gaskets.
May 18, 200718 yr Crank seal as well. Do you mean a complete oil pump, or the O-ring seal? Check the backing plate screws as they sometimes work loose. I've also heard of cases of some Aluminum flash remaining in one of the oil galleys around the oil pump. Something else to check for. I think you are aware of the proper torque for the crank pulley (but thought I'd mention it). Commuter
May 18, 200718 yr if your taking the engine out, do the separator plate. if the engine has been sitting for a while, do the rear main seal.
May 18, 200718 yr Author by oil pump seal i meant crank seal too. had 3 loose screws (the oil pump, not me, i have far more). i'm doing the clutch tonight, will check the separator plate whether it's plastic or not and replace the gasket. car was running fine and i just yanked the motor so i'll leave the rear main. didn't want to start another thread, but wasn't sure about the cams...the EA's have the o-ring with the seals and i've heard people talk about "half moons" and spark plug hole gaskets. i got the spark plug gaskets. the dealer told me there was no oring for the cams to worry about. what are the 'half moons'?
May 19, 200718 yr I haven't heard of the 'half moons'. My '00obw 2.5L I'm pretty sure doesn't have the cam cap o-rings, at least I couldn't find them. I know both my '94 and '96 2.2L's have the cam cap o-rings; the RH one looked like this on the '94. It was leaking and the old o-ring was rock hard. The new one was nice and supple:
