May 22, 200718 yr Hey all, I recently did the timing belt on my '93 legacy with the kit from Gates. Now I go to order the Gates kit again for my girlfriend's '95 legacy (also non-interference) .....and they are showing a different *and more expensive* kit for a 95 vs. a 93. Are they assuming all 95 2.2s are interference, thus the different kit? Her '95 is a 5MT ....so I KNOW its not interference. Shouldnt I be fine with the '93 kit? Thanks!
May 22, 200718 yr i'd check some online subaru parts places and online stores like advanced and such and see if they're all showing a different part number as well. you're definitely right, all 95 2.2's are non-interference for sure. you say you're looking at a "kit". maybe the timing belt is identical but the kit is different?
May 22, 200718 yr Author I just checked.....the timing BELT #s are the same the IDLER #s are different! I thought an EJ22 was an EJ22!?
May 22, 200718 yr Same thing. The only difference in idlers, and its not consistant just because of a year thing is bolt length and how shallow the mount for the idler is.
May 23, 200718 yr Author Same thing. The only difference in idlers, and its not consistant just because of a year thing is bolt length and how shallow the mount for the idler is. So the kits are interchangeable?
May 23, 200718 yr More then likely the difference in belts is that one is a 60,000 mile t-belt, while the other is a 100,000 mile t-belt. Either way, the belts should be 100% interchangable.
