TurboTbird Posted May 31, 2007 Share Posted May 31, 2007 My 95 legacy was flashing the CEL with error code P0115 Engine Coolant Temp Circuit Malfunction I just replaced the sensor with an OEM part. The job wasnt that bad, pull off the intake and the ten thousand hoses going to it, unhook a few lines, use a 19mm deep and remove the sensor and throw the other one on, about a 20-30 minute job, not bad. So far, no CEL. Ill let you guys know if it comes back on. Quote Link to comment Share on other sites More sharing options...
