June 7, 200718 yr As far as i know there is nothing made for subarus. Theirs a weber adapter that i've seen pictures of. Shadyirshmen had a nice one for a jeep that he mod'ed to fit his ea82 wagon. I went to homedepot and got some tube and made my own. If you search for snorkel's you should find. some pictures of different styles. heres mine. The intake is really loud so i ran it farther back so it was behind the drivers window. I Also built a screen to keep water out of the filter.
June 7, 200718 yr This is what we done to a mates car for a snorkle. It's a 2" pipe welded up with a proper snorkle top. The EA82 now uses a modded EJ22 airbox and filter, and a weber
July 22, 200718 yr the weber part number for the snorkel adapter is 99010.357 expect to pay around $110 for it (kinda steep) also you would need to get some sort of air filter between the snorkel and the carb (custom)
July 22, 200718 yr ive looked into this some and if you get one for an early 80's toyota pick up, you should be able to modify it some to work right.... you just have to pay the cash for it, its not cheap... thats the only drawback....but, other than that, i used some shop vac tubing and some pvc pipe for one before, worked out quite well, the downside to that was that it kinda killed the breathability of the motor. it had problems getting to and staying at highway speeds, not that it didnt before, but the snorkel only made things worse. that was on a ea82 wagon though, dont know how it would do with an ej motor. might have to try it sometime...
July 30, 200718 yr This is what we done to a mates car for a snorkle. It's a 2" pipe welded up with a proper snorkle top. The EA82 now uses a modded EJ22 airbox and filter, and a weber Now that is saweet! How does it run with that?
July 31, 200718 yr He says it runs pretty bad because of the cool air the jetting is wrong.. But I'm thinking maybe it's just hes using some weber off a 4L engine with what ever small jets he could find.. I can't really say anything though as I haven't driven many EA82's and this is the only one with a weber (I think it's a 34/34. Hes got a better one to go on, a 32/36.) Hes also gone and siliconed EVERYthing under the hood.. He took a plug lead off the other week and after a deep water splash it was running of 3. So I think his silicone works, it's just not service friendly. I used to think snorkels were not needed for the amount of money/work you put into them.. Then I came across a water hole that I didn't want to do because it was as deep as my air intake.. He probably would of went thorough no troubles.. So maybe it's time for a snorkel.
July 31, 200718 yr this is just me here, but if i were to make a snorkel out of metal tubing or pvc, i would go 2 1/2 to 3 just to make sure im getting plenty of air to the motor. since my last snorkel kinda choked the motor and it was 2 inch pvc and a shop vac hose......but thats just me...
August 1, 200718 yr Bigger the better yes.. But this one my mate has didn't make any negative difference to performance and it is only 2" fence post with plain angle cuts and welds not smooth bends.
