EGR warning light?
I have been searching for information on what the egr light on my dash means and havent had much luck. I have an 86 4wd wagon with the 1.8l engine it has a hitachi carb. Obviously I assumed that it means that the egr valve is probably faulty but i was wondering how it derives this information. The valve seems to move freely so i was wondering if some other part of the egr system could be at fault or the "sensor" that activates this light might be the problem.
I didn't know there was a light for that on the dash. I think you are right about the warning being caused by a electrical circuit. The EGR circuit usually has a solenoid wired to it and the ECU monitors that.
The light activates after 60,000 miles to tell you to check/clean the EGR valve. You need to reset the light. up under the dash, way up against the side wall, drivers side, you should be able to see 3 connectors, blue I think. Tkae the 2 connected toghether, unhook them and plug into the unused connector. this resets for another 60,000 miles,
thanks for the tip. it worked just like you said. that plug is right behind the fuse panel up high it only has one wire in it. mine was blue on blue then i pluged in the green connector and it reset the light. Thanks again
Wow. Wished I had known this before, great information. This was the only light blaring at me on a Wagon I sold long ago.
  • 1 month later...
I had to remove the fuse holder to be able to reach the connectors, but it worked thanks.
  • 7 years later...
