is speedometer gear in the transmission fixable?
my speedometer doesn't worked. it's not the cable and it's not the instrument cluster...so it must be inside the transmission/front differential. i'm hosed aren't i?
You are looking at the VSS#2
Here is a picture of what might be bad
Here is a post that explains in much detail what you
may be describing
VSS#2
-would be a good idea to tell
the folks what car this is
okay looks like i'm hosed. gotta swap trans. how was that guy offering to fix it for $100? he was going to pull the trans and tear it down for that much?
