July 3, 200718 yr would someone please advise me of a method to install the short rubber hose between turbo and engine block. thank youi:Flame:
July 3, 200718 yr Ewww, you picked a good one:-p Remove all the heat shields, if you can. Remove the downpipe, then you should be able to access the line.
July 4, 200718 yr unbolt the turbo from it's flanges. lift it up and put the new hose on the turbo. Then guide the hose onto the tube on the block as you lower the turbo. All heat sheilds must be removed and it takes tricky clamp work.
