July 23, 200718 yr Ok i did some checking in the search and i didnt see this one pop up 1988 subaru dl push button 4wd if one day i wanted to convert it to the dual range transmission what would i need to do other then pick up the tranny and make a few arangements in the floorboards Ben
July 23, 200718 yr The hole in the floor should be the same. All you'd need is the d/r tranny and its shifters, and the console from the donor car.
July 24, 200718 yr it all bolts up the same parts you will need: transmisson with shifter, shifter boot console plate parts on the car that will fit the same: driveshaft, axles, tranny mount, clutc-flywheel-pressure plate really the only thing you will have to find that matches is a console that is the same color. the threaded end on the clutch cable may be different, if so use a lug nut as a spacer
July 24, 200718 yr Been there, done that! When you do this conversion, I highly recomend replacing clutch assy.(if already standard) and rear main seal, even if it's not leaking. 1988 subaru dl push button 4wd I assume that is a standard 5 speed and not an automatic 4 with push button 4wd. If it's the latter, you will need to get a pedal assy with a clutch pedal, plus a flywheel for a standard tranny.
