July 30, 200718 yr Hi there, we are looking at a 99 legacy sedan to replace the 91 wagon, should it have keyless entry and these owners just don't have the fob? is it the same fob as my 00 OBW? I have seen the security system upgrade on subaruparts.com which makes me think that it should already have keyless entry. Thanks!
July 30, 200718 yr Hi. Hm...cars101.com says [1999 Legacy] Brighton, L, and 30th Anniversary L: more horsepower and torque with 1999s "Phase II" 2.2 liter engine, smoother shifting transmissions, wide spray windshield washer, L models pre-wired for easier keyless entry installation at the dealer. GT models had standard keyless entry.
July 30, 200718 yr the keyless remote box is easily visible. it's on the lower drivers side kick panel, to the left of the brake pedal, up against the wall. it's huge and says KEYLESS ENTRY on it, very obvious.
July 30, 200718 yr Author the keyless remote box is easily visible. it's on the lower drivers side kick panel, to the left of the brake pedal, up against the wall. it's huge and says KEYLESS ENTRY on it, very obvious. Thanks, I will check it out, it's the anniversary L edition so it probably didn't come standard then.
