overkiller Posted December 6, 2003 Share Posted December 6, 2003 Can anyone tell me what wire plugs into the big sender on the bottom of the oil pump on an EA82 with the gauge? The wire coming off the sender is black/yellow and I thought there was a wire that came out of the loom under the radiator for it to plug into but now I can't find it. If someone can tell me what color the wire is and where it goes I'd be very thankful. Thanks Travis Link to comment Share on other sites More sharing options...
Skip Posted December 7, 2003 Share Posted December 7, 2003 Travis, the wire comes from the wiring on the engine, not the rad. Look up on the engine front by the goose neck, it has a clip beside the oil dip stick. Mine recently came out of the clip and got caught in the crank pully/fan belt. The remains were found up near the goose neck. This is a single wire by the way, as you ask for oil pressure sending wires. It is in a black sheath. Hope this helps, if you need a pict, please ask Link to comment Share on other sites More sharing options...
