280zx injectors
Just wondering if any one knows if the 280zx injectors are the same as the vl turbos commodore?? i just call up a shop they told me there the same and would fit my subaru if the 280zx will??.What do i need to do the 280 injector upgrade i have a sard fuel regulater and a walbro pump and getting the injectors on the weekend do i just put in the injectors up the fuel regulater to the same as the 280zx and away i go or is there more to it,thanks for any help.
Yep they fit. There have been a few people that have talked about those before on here. I am sure there is a bit of info on setting them up with mega squirt or something like that.
Cool i just got some they flow at 260cc,dose anyone no what the stock flow rate of the subaru is? and is the injectors,fuel reglator and fuel pump all i need to do the bigger injector upgrade? thanks
The stock flow rate for EA82T injectors is 180cc/min and the stock FPR rating is 36psi, and that is at max. As for static pressure, I have no idea. So far, you are moving in the right direction. Good Job!:clap:
Patrick
No, you'll need an aftermarket engine management computer (megasquirt, link, etc.). You can get the car to run with the stock ecu and nissan injectors, but it wont be nice at all.....
