ECS help HELP
today my ECS light kept coming on and off so i stopped and wiggled the wires around my carb and in the engine compartment i just had my trans fixxed so i thought they might if pulled a wire and it was'nt connected right .
6 blocks later my engine cuts out as my ECS light came on pop hood and a little smoke around my carb and the smell of burt plasic.
can someone give me some ideas what to do after 930 on trans work and new cv axles i'm broke
call Glenn at 951-852-0929 the code is 64 vacuum line control valve or circuit ????????????? what the f does that mean
Stab in the dark here, but you should definately check your Air Injection valves, the AIS (Air Injection System) uses passive "suck" valves with a reed inside. When the reed breaks raw exhaust is allowed into the intake, and it will melt the plastic "silencers" used to muffle the sound of the system. This plastic then gets sucked into the carb and jams up the throttle plates and fuel passages.
