October 26, 200718 yr I just found this on legacy central... http://www.graphics.cornell.edu/~v/b10scan/ way cool!
October 28, 200718 yr that is awesome... i will have to try that. now i just wish i wouldnt have striped that connector out of my harness when i did it. -=Suberdave=- http://www.suberdave.com
October 29, 200718 yr well i made one and tryed to use it on my EJ20G, no luck. it gives me an error and says the ROM is unrecognized... but i will see what i can do about that. i would love this thing to work on my car... as i see it. if it works on the EJ22t it should work on the EJ20G. the ecu pinouts are 90% the same and so is most of the wiring. well the code is opensorce so i will see if i can get it to work... -=Suberdave=- www.suberdave.com
October 29, 200718 yr Did you have to boot your laptop in DOS, or can the program be run through Windows in the DOS command prompt?
October 30, 200718 yr booted right from the bootable CD -=Suberdave=- http://www.suberdave.com Care to give me a rundown on that? I burned b10scan.iso to a CD, and told Windows to boot from that drive first but still nothing pops up. Basically, explain it to me like I'm a five year-old.
October 30, 200718 yr Care to give me a rundown on that? I burned b10scan.iso to a CD, and told Windows to boot from that drive first but still nothing pops up. Basically, explain it to me like I'm a five year-old. you have to burn it as a backup not just an ISO as a data file on a CD. i used NERO 7.* and just burned as a backup and it put two files on the CD. then i put it in the rom drive and start up the comp, and it boots from it... -=Suberdave=- http://www.suberdave.com
October 30, 200718 yr Author I haven't made the cable yet, so I haven't actually plugged it into the car. but if you just double click on the b10scan.com file in windows XP, and it loaded in a window.....
October 30, 200718 yr I haven't made the cable yet, so I haven't actually plugged it into the car. but if you just double click on the b10scan.com file in windows XP, and it loaded in a window..... that works too. but on the webpage it recomends running it from a boot disk, this way the program has 100% of the CPU and memory, and the program can update faster... -=Suberdave=- http://www.suberdave.com
