ejmartin Posted November 7, 2007 Share Posted November 7, 2007 I've got a 99 legacy gt with a broken bumper cover and i was thinking i would replace it with an outback cover so i could have the bigger round lights and be a little different.. does anyone know if a 96 outback front bumber cover will fit on my 99 legacy gt?? Are they the same?? thanks in advance!! Quote Link to comment Share on other sites More sharing options...
john in KY Posted November 8, 2007 Share Posted November 8, 2007 Good chance the beam will also have to changed. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted November 8, 2007 Share Posted November 8, 2007 I've got a 99 legacy gt with a broken bumper cover and i was thinking i would replace it with an outback cover so i could have the bigger round lights and be a little different.. does anyone know if a 96 outback front bumber cover will fit on my 99 legacy gt?? Are they the same??thanks in advance!! it should bolt right on. Quote Link to comment Share on other sites More sharing options...
ejmartin Posted November 8, 2007 Author Share Posted November 8, 2007 it should bolt right on. Has someone done this before so i know for sure it will fit?? Quote Link to comment Share on other sites More sharing options...
subaru360 Posted November 8, 2007 Share Posted November 8, 2007 The cover will fit. You might need the outback grille. The Outback grille is taller than the standard legacy grille. They both mount the same, but if you put a legacy grille on an outback, there is a gap at the bottom. The Outback bumper cover has a dip in the top for the outback grille. I don't know if the legacy gt has the taller grille, I don't think so. You may also need the outback bumper beam, not sure on that, if you are going with aftermarket foglights it might not matter. Quote Link to comment Share on other sites More sharing options...
ejmartin Posted November 8, 2007 Author Share Posted November 8, 2007 Thanks for the info! i think i'll give it a go a see how it turns out! I was planning on just using the outback driving lights.. I'll let everyone know how it turns out! Quote Link to comment Share on other sites More sharing options...
thatswhatshesaid Posted November 17, 2007 Share Posted November 17, 2007 Would any of the wiring for the foglights change? It doesn't seem that it would, but I've never cracked a GT bumper open to look. Quote Link to comment Share on other sites More sharing options...
subaru360 Posted November 17, 2007 Share Posted November 17, 2007 I just noticed somebody around the corner from me has a LGT sedan. It looks like the LGT has the same taller grille as an Outback. Quote Link to comment Share on other sites More sharing options...
