November 20, 200718 yr hey got my weber on and just wondering how to wire the electric choke also how to wire the plug that went to the old hitachi so that the car will run. the plug im talking aobut gose to the magnetic solinoid thing on the side of the carb. and when i unplugged it form the carb the car would die but now it has nowhere to go. so dose any one know how to rewire that and the chocke thanks. PS> the engine is an ea82 the car is an 86 gl wagon no CPU. the carb is a 32/36 dgev thanks again Rob. Rob:cool:
November 20, 200718 yr As I don't have a Weber I can't help ya on the choke. But I'm thinking the wire to the solinoid your talking about is for the anti- dieseling on the Hitachi. (is it on the front drivers side of the Hitachi?) Which will cut your fuel when unplugged while idling. (at least it does on mine) If the Weber does not have that feature than you can proly ignore it....(but would have to insulate it from accidently grounding out) I'm sure by morning someone with far more Weber knowledge than I will have your good answer.
November 20, 200718 yr You need a key "on" 12 volt to the choke connection. Follow the choke wire off of the Hitachi to it's connection, that's the terminal you need to use on the vehicle side of the wiring. Most Webers don't have the anti-deiseling valve, so nothing else to wire up electrical.
November 28, 200718 yr Author ok so after much cranking and tinkering. it now RUNS WOOOOHH and it eunns good idles nice it dosent pop or misfire. the problem was it wasent geting any gas i needed to puta new plug on the fuel pump but all is well yeah baby it runns so fine Ps dose any one know how to tell what type of jets you have ?? thanks Rob.
November 28, 200718 yr Okay Rob, since this thread was buried in the "Off Road" forum I'll give it to you as a free-bee, a nugget of pure gold, the beggining of knowledge............ http://www.ultimatesubaru.org/forum/showthread.php?t=29778&highlight=weber Later, tim
