Multiple ABS Problems
Hey Fellas....got a 1996 legacy L ej22 with a 5 speed...the abs light came on about a year ago....and just had time to pull up the flash codes......both rear sensors are open and it says there is a valve relay problem....does anyone have any information on this or had the same problems.....by the way the car is lowered so could that have anything to do with it......just wondering what i should do first to try and fix?
a search and skimming through some ABS threads would answer this. try cleaning up the sensors first. they can attract all sorts of debris. just follow the ABS wire behind the hub and unbolt it. the fronts can be removed without even jacking the car up or taking the tire off. not sure about the rears, but doubt it's difficult.
i believe there are common ABS relay issues...common to 1996 actually, search on this forum and yo'ull find the information. i thought it was EJ25 stuff only, but a search will give you all sorts of info on it.
