Steering rack interchange?
yeah i wouldn't think twice about swapping EJ racks...but i could be wrong, i would just assume they're the same based on some not quite related work. i think you are correct in saying the ratios will be the only differences.
doesn't help you - but i use EJ steering rack bushings on XT6's, perfect fit, i think they change very little with the steering racks.
Yeah many EJ racks will interchange. Exceptions are 05+ Impreza because of the different crossmember/mounting stuff and also other newer ~02+ stuff may not work because the spline count on the column changed. But I think if you take the double U-joint thingy that matches the rack it opens up more options.
Your 93 Legacy does have the quickest ratio short of the STi, though.
