December 21, 200718 yr Hopefully someone can recomend a good auto body shop in the Boston Area. My daughter's 06 Impreza was invoved in an accident. She just relocated there and does not have any resouces available to her. She is Ok the car was hit my a Volvo, Impreza looks good compared to the Volvo. Body damage as well as bent azle Any suggestions about getting to a good repair shop Thanks for the help
December 24, 200718 yr You may want to post in the meet & greet forum as well. Also, if you don't get any suggestions, you may want to check out the regional forum on http://forums.nasioc.com/forums Josh
December 25, 200718 yr nydsol, Try this, http://www.cartalk.com/, this is the home page for the car talk guys. About half way down is a spot called "Mechanics files", plug in a zip and you can search for repair shops in the area. I put in a generic Boston zip code and got about 20 responses, mostly repair shops but they did list quite a few body shops. Worth a shot if your still in need. Best of luck.
December 26, 200718 yr i had my car worked on in marloborough, it came out really good, but it took a while, and isn't really close to boston.
