January 3, 200818 yr When I spray washer fluid on the windshield, the passenger side spray pressure is fine, but the driver side just trickles out. I've replaced the hoses and junctions and cleaned the nozzles. Could it be the pump that's gone? If so, how much am I looking at to replace it and are the parts readily available? I have a '94 Loyale. Thanks, Brian
January 3, 200818 yr pumps are cheap and universal, about 15.00 at any autoparts store. Have you cleaned out the squirter thingy? It may be clogged with goo, or it can be eroded inside and no longer any good. Swap sides and see whats happens. nipper
