January 24, 200818 yr Just thought I'd share... 4:30am, 20ish degrees, frosty windshield on the wagon, can't find scrapper no juice in the washer. Turn car on, blast heater, go retrieve washer fluid from garage, fumble with container flashlight and hood, drop flashlight on foot, curse my slippery fingers and bleary eyes, flip open lid and fill.... the COOLANT OVERFLOW!! dang... I wondered why it took like a third of the bottle of washer fluid:dead: at least it was still cold, no chance it got into the rad. who says only monday mornings suck? thanks for visually listening Will-
January 24, 200818 yr The newer OBs ect hold 1 gallon of washer fluid. No car mentioned. If you do remove it, be careful those those bolts like to snap like frozen carrots.
January 24, 200818 yr Author The newer OBs ect hold 1 gallon of washer fluid. No car mentioned. If you do remove it, be careful those those bolts like to snap like frozen carrots. Yes, '96 Legacy OB, 1 gallon of washer fluid was what I was expecting, thus my faint surprise at filling it so quickly.. Thanks for the tip on the coolant over flow bolts, i'll be careful. Will-
January 24, 200818 yr [...]Thanks for the tip on the coolant over flow bolts, i'll be careful.[...]Why bolts? Grab a turkey baster or similar device, and suck the tank dry as possible; add a piece of vacuum hose or fuel line to extend the tip if necessary. Don't be concerned if a small amount remains. You could also siphon it, but don't start the siphon by mouth! If you do use the turkey baster, buy a new one before the next bird.
January 24, 200818 yr OB99 is right - you could even use the overlow hose from the rad as the baster extension. Don't let Momma catch you though.
January 24, 200818 yr Author Good idea gents. I just happen to have a baster sitting around... thanks Will-
