Milkshake leaves bad taste
So, my EA71 WAS running fine. All of a sudden, MILKSHAKE!!!!!!.
I researched and found that the Freeze plugs are under the valve covers.
I replaced them this morning and put the rocker arms back on. The engine was running so good before this happened. Now it seems like it isn't getting gas????.
I drained the old milkshake oil. I refilled it with an engine flush (mainly kerosene) and new oil. I planned on draining this after runing it for about an hour and refilling the oil again.
Problem is , it wont run unless half choked or something. I am really stuck here. I don't want to have to tear it all down unless absolutely necessary. Thes carb is brand new. The fuel pump is brand new.
Could it be a simple as the PCV???? Or it the engine screwed after the freeze plug blew? This milkshake was coming out of the valve cover.
