March 29, 200818 yr Author It is: IDLE CONTROL SYSTEM MALFUNCTION (FAIL SAFE) What do you think control the idle? The Idle Air Control Vavle (IAC)!!! It is not the only possibility, but a good place to start. Perhaps it has a loose hose? Loose connection? You can't just dismiss it without checking it. NOT DISMISSING IT been there tried that 3 different IAC'S. 1 from a solid running car(mine) all to the same effect, NONE and i did resistance tests on the wiring, no issue there either i also did a hard test of the shifter switch to no effect im left to believe this NSS is the answer however unlikly that is, it has solved the problem for some other folks today im testing the intake gaskets for leaks(soob360's idea) and im up for trying anything any one can think of
March 29, 200818 yr NOT DISMISSING IT been there tried that 3 different IAC'S. 1 from a solid running car(mine) all to the same effect, NONE and i did resistance tests on the wiring, no issue there either i also did a hard test of the shifter switch to no effect im left to believe this NSS is the answer however unlikly that is, it has solved the problem for some other folks today im testing the intake gaskets for leaks(soob360's idea) and im up for trying anything any one can think of Except you're car doesn't have and doesn't really use an NSS. In fact calling it a nuetral *safety* switch is a misnomer. It is the Clutch switch that is used for the *Safety* lockout for starting. The Neutral switch is on the trans. The ECU uses it to know when the car is in neutral to provide gas for idle at throttle closed.(throttle closed in gear, coasting is assumed,no gas is injected) Not trying to naysay, but I think you are totally on the wrong track. You don't have a Nuetral switch that effects engine idle. And sounds like you tested the Gear indicator switches and they are working.
March 29, 200818 yr Author Except you're car doesn't have and doesn't really use an NSS. In fact calling it a nuetral *safety* switch is a misnomer. It is the Clutch switch that is used for the *Safety* lockout for starting. The Neutral switch is on the trans. The ECU uses it to know when the car is in neutral to provide gas for idle at throttle closed.(throttle closed in gear, coasting is assumed,no gas is injected) Not trying to naysay, but I think you are totally on the wrong track. You don't have a Nuetral switch that effects engine idle. And sounds like you tested the Gear indicator switches and they are working. did you read the other posts on 1507???? just go read them and if you have any idea what OTHER direction to go in say so, until then im trying the NSS
March 29, 200818 yr did you read the other posts on 1507????just go read them and if you have any idea what OTHER direction to go in say so, until then im trying the NSS Let me know what part they send you , because the Autos DO NOT have a *Neutral Safety Switch* You will either get the selector/ inhibitor switch assembly for the Auto (which you've say you've already tested) Or you'll get one of two parts for a manual. Either the Nuetral switch which screws to the side of the trans a the rear. You're auto trans does not have one. Or you will get the Clutch/Starter interlock switch, which bolts to the clutch pedal something you also don't have. I am here trying to help, so don't take offense. But you guessed, and you have guessed wrong.
March 29, 200818 yr Let me know what part they send you , because the Autos DO NOT have a *Neutral Safety Switch* You will either get the selector/ inhibitor switch assembly for the Auto (which you've say you've already tested) Or you'll get one of two parts for a manual. Either the Nuetral switch which screws to the side of the trans a the rear, or the Clutch interlock switch. You're car uses neither. I am here trying to help, so don't take offense. But you guessed, and you have guessed wrong. We make the mistake of calling a NSS an inhibitor switch and the other way around. Some of us over 40 do that. so shoot us. nipper PS So do a alot of mechanics.
March 29, 200818 yr We make the mistake of calling a NSS an inhibitor switch and the other way around. Some of us over 40 do that. so shoot us. No need for shootin:bang: If that is what you meant that's great. But How would that affect the idle? unless it's not sending the signal to the ECU that the car is in *D*? He says he *hard tested* it? I would assume that means jumpering the wires for the *D* signal and driving. Which should tell the ECU it's in *D* and be all it needs unless there is a problem elsewhere. All the Idle/Nuetral Switch problem combos I've read about are with Manuals.
March 30, 200818 yr Author No need for shootin:bang: If that is what you meant that's great. But How would that affect the idle? unless it's not sending the signal to the ECU that the car is in *D*? He says he *hard tested* it? I would assume that means jumpering the wires for the *D* signal and driving. Which should tell the ECU it's in *D* and be all it needs unless there is a problem elsewhere. All the Idle/Nuetral Switch problem combos I've read about are with Manuals. enough arguing over the NSS/inhibitor switch gloyale do this for me take my symptoms and code and tell me what to try if you read the post you know what i did so far and i have tried alot more than ive stated as well so please just give me a freaking idea of what to try next i dont take any offense to any of this but all this chit chat is besides the point i got a problem and you aint givin me any new ideas just knockin on what i have come to so far so stop talking, start thinking why does it stall out, then restart oerfectly why the code 1507 its not the IAC, its not the intake gaskets its not the coil,wires, plugs.... its not the knock, throttle body, injectors the trans is completly rebuilt car runs and drives perfect, until the stall and code think people THINK monday im putting something in the trans that may or may not fix it but at 61 bucks its a cheap try
