April 23, 200817 yr I assume 90-94 fenders, lower valance and hood will fit 94 Loyale but will GL/DL back to 85 fit? I can weld up the rust holes in fenders and valance if necessary. Hood has a ding in corner . Are headlights interchangeable 85-94. Mine has moisture in the right side. Thanks.
April 23, 200817 yr yup those will fit as well. any EA82 sedan, 3 door, and wagon will work from 85 - 94.
April 23, 200817 yr The only difference is the side trim, and that can be changed out. I'm pretty sure the hole layout is the same. Andy
April 24, 200817 yr i have noticed that the front valence bolts will be 12 or 10 mm depending on year. but the holes locations are the same. i recommend pulling hte bumper off furst if you are changing fenders, since the front most bolts are bhind the bumper skin
April 24, 200817 yr i have noticed that the front valence bolts will be 12 or 10 mm depending on year. but the holes locations are the same. i recommend pulling hte bumper off furst if you are changing fenders, since the front most bolts are bhind the bumper skin Good call. I have noticed that sometimes those bolts are phillips head and sometimes they are hex (not sure if that ties in with the 10-12mm difference or not). Living around here, they usually don't come out without a fight if they are phillips. I once removed both fenders and the valence as a unit from a GL in the junkyard because I couldn't get the four valence bolts out. I also fit the entire unit into the back of a 4Runner, which surprised both me and the junkyard man. Andy
