1996 Legacy LSi
the cruise control assembly in the passengers side strut tower has a vacuum tube just above it (like 1/4"). where does this hose go? it comes from the cruise control actuator (with the throttle cables) over on the drivers side.
on my 1995 that hose wraps down and attaches to the bottom of the cruise control assembly (passengers side gizmo). but there doesn't appear to be anywhere to attach the hose to on my 1996?
maybe i broke it when doing the engine swap...or is it routed differently on 96's?
my 97 impreza is a completely different set up, so that doesn't help.
someone snap a picture of where that vacuum hose goes on a 96 or similar set up?
take a look...is it the vacuum tube in the center of the Pic.? if so it wraps around and attaches to the back side of the cruise control cable which is attached to the firewall.....look on the backside of the black circular thing (attached to the firewall) with the cruise control cable coming out of it......at least this is how it is on my 96' legacy L
awesome EVO!!!! that's the one. the hose travels to the right in the picture and appears to go UNDERNEATH that cruise control assembly....where does it attach to down there? the other side is currently attached.
thanks!
thanks EVO. that was perfect. when i finally looked really close i noticed that the nipple the hose goes into is cracked off. everything being black and dark i didn't notice it until i knew exactly where to look.
now to find another cruise control assembly....i'm probably going to steal your picture in my parts wanted thread!
thats cool....glad u got it all figured out....or if you have the broken nipple you could JB weld it back on.....:lol:
i don't have the nipple, probably broke it a long time ago when i pulled the engine "just a swangin'....."...probably knocked it off then. just now looked into fixing it. i have another on the way, so i'm good to go!
