2wd ej swap impreza 2wd tranny
anybody used an impreza front wheel drive tranny in an EA82 car? (also front wheel drive)
I do know that the spline counts are supposed to be the same. any thing that may make it not work?
I COULD use an adaptor on the EA trans... but it is leaky..
it'd be exactly the same as using an AWD trans, except you wouldn't have to worry about the driveshaft.
custom trans crossmember/mount, and modified linkage, and you're hot to go.
hmm I wish they had been lazy and put the center bearing mounts in all the cars....
thanks for the info!
