Lifting a 1993 awd Impreza (2 ")
What are the dangers of lifting 2 inch at every strut upper spring seat ?
There is now a standard thin rubber seat.
People suggested me to change these for thicker (2 inch more) hardrubber rings.
Can I expect more problems than a higher point of gravity and more wear at the axles ?
Anything more ? If it was that easy , why I never read about it ?
Please a reply by an "lift" expert.
Thanks !
You can accomplish the same thing by installing a set of Forrester struts.
Subaru is like a white elefant at "Place de la Concorde" where I live.
No way to get something other than local solutions.
here is my impreza with forester struts
you could also have a machine shop extend the springs or make new longer ones, or better yet, fabricate blocks that go between the strut top and the car
here is a complete lift system that they sell, you could order one for your vehicle, i know brazil is quite far to ship, but boxes do get there.. i send gifts to my mom every 6 months :)
Looks impressive , where to order and for what price ?
That lift kit is made by the forum member Scott in Bellingham and sold on his site, but it's for an EA82 car, so it won't do you any good. Currently there aren't any EJ lift kits. Scott is making up a lift for his Legacy here though. Not sure how that translates to the Impreza.
AA offers one still.
As well as a few Australian companies whose names escape me. Scorpion?
You're posting here, so you have internet.
Order them online.
If you just lift the strut tops, you may get funky camber if you don't make you're spacer with a bit of angle.
No angle=pushing top of strut outward.
Order them online.
Right, but the imp/legacys have camber adjusters and can be pretty much leveled out with 2 inches of lift.
You would do well to post this in the off road section.
I thought about it , but it is just needed for every day's roads...
Well, the Outback Sport had a little more lift to it from the factory, right? Though not 2". Would struts from an OBS be an easy helper to get higher with no worry of fitting, or were those cars different only by having taller tires than other Imprezas? :confused: I'm new to the Impreza world and know very little about them.
I just ask myself about the brake tubings , no need for longer ones ?
