June 16, 200817 yr I need to replace the bolt that holds the plate (EA81) which attaches to both the leading rod and holds the tranny cross member, it also passes through a 3" lift block. Can anyone tell me the exact size of this bolt? IIRC, it was a 19mm head and a 1.25 thread. I'm not sure of length and bolt diameter. Thanks a bunch!
June 16, 200817 yr Thanks a bunch, Scott! What is the length necessary for this? 12mm-1.25 x 100 mm for a 3" block up front
