Help Weber/timing!!!!
OK Im new to all of this so Mr Incredibles' I need your help! I have a 85 brat and I have In stalled the weber with the help of all those threads of information that all of you have provided. Thank you all for providing the info need to do any tasks at hand. So I got the weber installed correctly for the most part when i was trying to fine tone it I checked the timing and could not see the marks. With my hitachi on the dist was cranked all the way to the right or left how erer you look at it in order to get 9 degrees out of it. so I pulled the dist to reposition it and well I *%^&@! up. I went back to square one found #1. Double and triple checked it to make sure I had the right location. My weber now spits fuel out of it!!!!
1. Remove #1 plug - find TDC using a drinking straw and with your finger make sure both valves are closed (air will push past your finger).
2. Align the timing mark with 8 degrees BTDC.
3. Install the distributor with the rotor pointing at one of the plug tower's.
4. Install the plug wires counter-clockwise from the tower you chose in the order 1,3,2,4.
5. Adjust final timing with a light off the #1 plug wire.
