EA-82 sr-ft-awd / dr-ft-awd gear ratios ??
Hi,
I am confused on the gear ratios in the single range fulltime AWD for ea82 and xt6, and dual range fulltime AWD trans for the rx.
my 88 fsm's shows the single range fulltime awd ratios are the same in ea82's, as in the xt6 sr/ft awd transmission.
my question, is that correct? not talking diff ratio, talking 2nd, 3rd, 4th, 5th gears, 1st is the same it says.
next question, is the Hi side of the fulltime awd dual range trans also the same as the single range fulltime awd? I'm reading they are.
my books seem to show they are, but am i reading this correctly?
I know all these ratios are different than the selective 2-4wd, the d/r selective 2-4wd and the 2wd.
I want to know or verify if all the single range fulltime awd trans, have the same higher ratios, but they had 3.7diff and xt6 had 3.9diff. also is the Hi range in the dual fulltime awd this same ratios? again i'm reading it is, but what is your view on it?
I hope that someone has some knowledge on this.
thanks for any help here.
