September 7, 200817 yr Well I got my lift all installed and tested this last week. Pic Here is a picture of it with outback rims and 205/70 15. The ride is great, I did replace the original rear struts that were totally blown. This was a pretty easy install, and I used my old springs. I was able to get everything back on even the front rear sway bars.
September 14, 200817 yr So is that Outback struts with the '91 lego springs? with that lift, di you use outback struts all around, or just in the back?
September 15, 200817 yr Author So is that Outback struts with the '91 lego springs? with that lift, di you use outback struts all around, or just in the back? Yes I was time since my old rear struts had 185k on them! I used my 91 springs and outback struts front and rear. The swap was really easy, and I was even able to get the factory sway bars back in place.
September 16, 200817 yr Are the springs significantly larger for the Outback than for the Legacy? I just PM'd you about the springs and tophats you have for sale. I'm interested in the rear springs, as the rear of my 92 squats so low I get tire-strike on my admitedly oversized tires. I know my struts are worn, and I'm looking at getting new ones (GR2's), but if I could find a bigger spring for the back, that would make a lot of difference. . .
