September 25, 200817 yr Fired up my '97 Impreza OBS last night to leave work. Let it high idle for a few minutes. Put it in gear, gave it a little throttle, it goes forward for about 2 seconds then starts bogging down and wants to stall. I let off the throttle, idles fine, even idles in gear and will roll. Gave it a little more gas, again it went for a couple seconds then bogs way down, almost dies, I let off and it idles fine. This goes on for about a half mile and even stalls once. I can barely get any momentum. Finally I just park it in a parking lot and get a ride home. I was thinking the tranny was finally gone. It's had some erratic shifting issues since I bought it a few months ago but nothing this bad. So this morning I buy a bottle of ATF and a bottle of Lucas transmission repair. Fired it up, let it warm up to temp, put in half a bottle of the Lucas as it says, and it idles like a champ the whole time. Now I'm sitting in park, hold it at 1,000 RPMs and in less than 10 seconds the RPMs drop, it bogs down, and I let off the throttle so it comes back to idle. Then I hold it at 2,000 RPMs with the same result. Now I rev it to 3,000 and it's fine; holds 3,000 + RPMs with no bogging or anything. After farting around for a half hour I just put it in gear and go; drives as normal as it always has. I've only driven it about a half mile though. Best guesses? I have a few of my own but would like to hear yours! =)
September 26, 200817 yr Did you get a check engine light at any time during this? Could be a lot of things to cuase this sort of thing and not even set off CEL such as maf and knock snensor.
September 26, 200817 yr Author After work it behaved itself; no problems and I hadn't really repaired anything. Last night I did the O2 sensor and knock sensor. Taking special care to make sure the knock sensor was at the 45 degree angle. Everything seemed normal this morning and the CEL stayed off. I guess it's fixed.... for now =P I've had many bad O2 sensors and knock sensors with no problems besides worse fuel millage. I'm not fully convinced this fixed whatever was ailing me; mostly because it behaved just fine after work yesterday before I even fixed anything. Glad I replaced those parts regardless. Still was the right thing to do whether it fixed this particular problem or not. Now I must drink Mt. Dew because I was up past midnight working on her... 6:30 AM came too fast!
