received EA81 dist. drive gear on crankshaft
:dead: received EA81 dist. drive gear on crankshaft
situation: engine was running fine, letting it warm up about 10 min. just idling -- go to turn on blower, and engine dies :confused:
try restarting and only get backfire :-\
after removing sparkplugs, drive it into the garage using starter -- uphill icy snow, close to garage door, had to use 4x4 and have help pushing
check timing and it's not even close :eek:
remove dist. shaft doesn't turn freely, must use force, not fun having to turn crankshaft to provide clearance for the gears to slip past
notice aluminum bits down shaft hole :confused:
drain coolant from block, remove radiator, hood latch support, crankshaft bolt, pulley, and seal
gear has a flat spot :banghead:
atleast I have 4 spare dist. to choose from, one with matching part # :banana:
received 2 from CCR
matching part # dist installed, had to swap vac. advance system
Edited by subiemech85
