cyberbackpacker Posted December 29, 2008 Share Posted December 29, 2008 I am in need of some tranny info: Does any 4x4 ea71, ea81, ea82 tranny have a straight cut bevel gear or spiral bevel gear design? Basically do you know of any subie tranny that might be possible to essentially flip the diff to use the 4x4 tranny in a rear mount application? TIA Quote Link to comment Share on other sites More sharing options...
4x4_Welder Posted December 30, 2008 Share Posted December 30, 2008 I remember seeing somewhere on here that that isn't possible due to the case design. Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted December 30, 2008 Share Posted December 30, 2008 Pretty sure it cant be done, if the EA trannies are anything like the EJ trans I tore down today, then no, because the pinion shaft is too close to the outside of the casing. -Bill Quote Link to comment Share on other sites More sharing options...
cyberbackpacker Posted December 30, 2008 Author Share Posted December 30, 2008 That's the rub... I know the EJ tranny's cannot, but I do not have much experience tearing into the older ea trannys and was hoping some of the gurus on here might have some more insight to offer... Quote Link to comment Share on other sites More sharing options...
Phizinza Posted December 30, 2008 Share Posted December 30, 2008 With case mods and no low range it could most likely be done. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted December 30, 2008 Share Posted December 30, 2008 I've heard of a neat possibility for automatics. You can replace the output to pinion shaft gears(which rotate opposite) with a sprocket and chain setup(which rotate toghether). Now this would only change the direction of the front pinion shaft, so something else would have to be done to reverse the rotation of the rear(or front, in a reverse mounting) output. For say, a RWD sandrail, I think a 2wd automatic would be perfect, either 3at or 4EAT. 3at would actually be way easier as it is purely mechanical. Quote Link to comment Share on other sites More sharing options...
cyberbackpacker Posted December 31, 2008 Author Share Posted December 31, 2008 Phizinza and gloyale, this is getting more like the type of information I am looking for. Does anyone maybe have pics of these trannies innards (aka with the cases split)? Quote Link to comment Share on other sites More sharing options...
4x4_Welder Posted January 1, 2009 Share Posted January 1, 2009 I can get you some pics once I get back under my turbo wagon. The parts should be here on Friday or Monday, so I'll jump under there and get some pics before I put the new rear housing on. Quote Link to comment Share on other sites More sharing options...
cyberbackpacker Posted January 1, 2009 Author Share Posted January 1, 2009 I can get you some pics once I get back under my turbo wagon. The parts should be here on Friday or Monday, so I'll jump under there and get some pics before I put the new rear housing on. That would be great; what tranny do you have by the way? Thanks. Quote Link to comment Share on other sites More sharing options...
4x4_Welder Posted January 1, 2009 Share Posted January 1, 2009 I have a 4EAT, awd. Same thing from late 80s to late 90s. Quote Link to comment Share on other sites More sharing options...
Phizinza Posted January 2, 2009 Share Posted January 2, 2009 I have a thread on here somewhere with the pictures from my old EJ/FT4WD/Dualrange gearbox swappies... http://www.ultimatesubaru.org/forum/showthread.php?t=71100 That should be it Quote Link to comment Share on other sites More sharing options...
