January 8, 200917 yr Maybe I overlooked this somewhere else but, sorry if repost I picked up a 91 Loyale EA82 AT 4WD recently and I am interested in doing a 5-lug conversion and brake upgrade. anyone have info n the swap or pics TIA Ben Edited January 8, 200917 yr by tractor pole add info
January 8, 200917 yr http://www.ultimatesubaru.org/forum/showthread.php?t=50400 search is your friend around here......the USRM section of the main board(where you go when you sign in,lists all the forums)is a reference setup for just such questions.;)cheers, brian
January 8, 200917 yr Only about half the parts that are needed for the swap are XT-6, on the front you can get by with knuckles and struts from an early Impreza, and if you are running a non turbo tranny, use 93 FWD impreza axles. The lower control arm needs to be XT-6 though. For the front brake calipers, you can use Impreza, but you loose your front e-brake, which is pretty useful and important. On the rears, the caliper can be normal XT or any GL-10 rear caliper, but the rotors and the backing plates have to be XT-6
