Turn signal quit, module location?
The turn signals and emergency flashers stopped working on my 1997 imprenza. Fuse is good. Where is the signal module located? I guess thats my next step.
Maybe you just ran out of blinker fluid?
Near the fuse block on the drivers side, i am just not sure which one it is exactly. Haynes is vague and i never had to replace one before.
nipper
personal experience here, it is by the fuse block just above and toward the driver just where the trim ends. It is a square black module with the wire harness facing the cabin. hope that helps.:)
Thanks Crash 321, I found and removed it. ai intend on replacing it Friday mourning. Ill reply.
