February 10, 200917 yr sorry if this gets old!!95 legacy lsi wagon,auto,180k.been searching for about an hour about torque bind and cant seem to pinpoint my problem.all brand new tires same tread,air pressure etc.put the fuse in,no problems,take it out,turn left and right,get the feeling of an old 4wd truck in low range,more so to the left.the awd does work when it is needed,get a little clunk but after that nothing even in a turn with the awd spinning.i am not getting a code on the dash at all.have replaced the filter and done the drain and fill method about 6-8 months ago,replaced with synthetic fluid.diff levels are good and were filled/changed at the same time as the flush.getting a little aggrivated at this car,love it,just hate sinking money in it only to discover that wasnt the problem or it is another problem!!!any info would be helpful with this before i pull my hair completly out!!! i have only posted once before,but got good info,hoping to get the same results again!!! hoping this isnt the $800-$1000 problem i have been reading about!!i am mech. inclinded to do most of the work myself,but as posted before,the whole electric testing and wiring stuff,a little shakey!! thanks!
February 10, 200917 yr If you are getting torque bind, but no code, you likely have sticking clutches. Replacing the clutches can be done trans in car, for about $150 in parts. CLutches themselves can be found very cheap actually
February 10, 200917 yr http://www.ultimatesubaru.org/forum/showthread.php?t=78467&highlight=torque+bind for info on the steps to check the problem and fix it if you need to...
February 10, 200917 yr TB seems to be in season right now. There are three people asking questions about it. http://www.ultimatesubaru.org/forum/showthread.php?t=83921&highlight=read+transmission+codes nipper
February 11, 200917 yr Author If you are getting torque bind, but no code, you likely have sticking clutches. Replacing the clutches can be done trans in car, for about $150 in parts. CLutches themselves can be found very cheap actually thanks for the info!!!!!sounds like this is it i hope?!?!?is this a part that has to come from subaru??if not any help finding these would be awsome,not too up on where to get subaru parts as i have not had to put many on any i owned before!
February 11, 200917 yr Author thanks to everyone for the quick help! i will deff. let you know how it goes!!
February 17, 200917 yr Author follow up on torque bind........thank you to everyone who gave input,picked up a junkyard tail shaft,ground down the clutch marks,put it all back together and no clunking!!!!!!the pictures that were supplied were a great help!!thanks again to all who helped!!!!!
