February 15, 200917 yr anyone know if i can fit a 3.0 in place of 2.5 if not im going to put 2.2 in but came across good deal but dont if i can thanks fellas any info would be great
February 15, 200917 yr you can put whatever you want in there. a V8 350 (already been done in a subaru), a turbojet engine (already done in other vehicles)...it all depends what you're capable of. i'm going to assume you're asking if it's a direct swap or not? the H6 engines are not a direct swap at all. you'll need to swap over the entire engine, body wiring harness and ECU and then splice the appropriate wires into your existing harness. huck put an EG33 in his Xt6 and phil put an EZ30 in his XT6, so yeah it's doable.
