sgregory Posted February 21, 2009 Share Posted February 21, 2009 Just purchased an 86 gl, the blower motor works intermittently. Checked for power at the motor, appears to be a problem with power coming in to the motor. I have traced the wires from the motor back and find no obvious shorts, what else should I be checking, is there a relay that could cause this? Any help would be appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
Cougar Posted February 22, 2009 Share Posted February 22, 2009 There is a relay under the dash that could very well be trouble. By turning on the blower and trying to get it to work by tapping on the relays you might be able to locate it. Quote Link to comment Share on other sites More sharing options...
sgregory Posted February 22, 2009 Author Share Posted February 22, 2009 Thanks I will give that a try. Quote Link to comment Share on other sites More sharing options...
