which LSD?
So I want a LSD 4.11 for my '92 legacy.
Where can I find this incarnation.
Is mine a r180 or 160 rear?
VLSD?
What cars should I watch for in the wrecking yards.
is this the same size/direct fit as WRX 4.11 LSD?
thanks in advance for any help.
Look for a '91 turbo legacy 3.9 viscous lsd and put the lsd guts into your rear diff along with the side cups/seals from the lsd unit.
the vlsd became standard in outbacks around '01 - '03. you can check at www.cars101.com to see. (or www.opposedforces.com/parts/) they are a direct fit you just have to get the right ratio. outback '03 manual trans are 4.11, auto trans are 4.44. they also put them in GTs.
you can search www.car-part.com, by '03 all outbacks had them. before that it an option maybe????? they call them locking, but i wouldn't rely on the parts, yard if some wrench turner mis-lables it or enters the info in the computer wrong........ you need to ask for a specific model and year that you know has a vlsd.
