Major Lazy Posted April 10, 2009 Share Posted April 10, 2009 I am in the process of installing the new oil pump and gaskets that were supplied with my JDM ea82t. There were 4 gaskets in the box with the oil pump: the mickey mouse, one round one that goes around the shaft and 2 other small ones labled O ring - CMS case. so yea I should know but what where do the small 2 go? I did not see them when I took the old pump out. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted April 10, 2009 Share Posted April 10, 2009 I am in the process of installing the new oil pump and gaskets that were supplied with my JDM ea82t. There were 4 gaskets in the box with the oil pump: the mickey mouse, one round one that goes around the shaft and 2 other small ones labled O ring - CMS case. so yea I should know but what where do the small 2 go? I did not see them when I took the old pump out. Sounds like the ones that go between the Camshaft case and the Head. Funny, not part of the oil pump:rolleyes: And they didn't include the shaft seal for the Snout of the pump? Quote Link to comment Share on other sites More sharing options...
Major Lazy Posted April 10, 2009 Author Share Posted April 10, 2009 (edited) And they didn't include the shaft seal for the Snout of the pump? WELL i said shaft but i think the one i was talking about is the same you say goes around the snout in the little groove. The little ones i am wondering about (2 provided) are small orings about the size of a dime, sub part #13089AA010. So when i change the oil pump there should just be 2 rings correct? the mickey mouse and the snout? Edited April 10, 2009 by Major Lazy Quote Link to comment Share on other sites More sharing options...
Gloyale Posted April 10, 2009 Share Posted April 10, 2009 So when i change the oil pump there should just be 2 rings correct? the mickey mouse and the snout? No, I meant the seal that is actually under the pulley on the front of the pump. It is a skirt seal, like a Camshaft of Main seal, but smaller. But all in all, there are three oil cantainment seals related to the oil pump. Mickey mouse, Large O-ring around the base, and the shaft seal presssed into the front of the pump, under the pulley. I guess THAT gasket company considered that seal part of the pump, even though it is easily replacable. Good news is, if you don't have you're t-belt covers on yet, you can install that seal on the pump without unbolting it from the engine, if you have already put it back in. Quote Link to comment Share on other sites More sharing options...
Major Lazy Posted April 11, 2009 Author Share Posted April 11, 2009 , if you have already put it back in. your funny, my name is major lazy for a reason. When i had the excuse to stop work, I did. Thanks for the info! Quote Link to comment Share on other sites More sharing options...
