April 11, 200917 yr so i have this old nitrous system have a guess how its hooked up? no idea. id like to change it to a wet setup, as cheap as possible. give me some resources to read and learn about this kind of thing. a book is best. yes i dont know what im doing and would LOVE to change that i found the instructions here http://www.zex.com/Base/Instructions/ZEX109.pdf seems not to be compatible with the subaru fuel regulator anyway Edited April 11, 200917 yr by erik litchy
June 12, 200916 yr Depends on the engine you are putting it on - what are you planning to do with it? This system is designed for an MPFI application using a TPS voltage trigger. The fuel pressure can be adjusted via an aftermarket regulator if the stock unit isn't compatible. There is nothing wrong with nitrous if it's used properly. Unfortunately it often is not. GD
